DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   3rd Gen Ram Tech (https://dodgeforum.com/forum/3rd-gen-ram-tech-65/)
-   -   i want to run my lows and hi's (https://dodgeforum.com/forum/3rd-gen-ram-tech/233688-i-want-to-run-my-lows-and-his.html)
dodgewhiteout Feb 18, 2010 10:24 PM
alright i got the aftermarket headlights that split my dual beam bulb in2 a seperate hi and low bulb...is there any way possible to make my hi's amd lows come whenever i turn my highs on????:icon_shrug:
98cherryram Feb 18, 2010 10:25 PM
Yeah, you could run a one way relay from the highs to the lows. If you do I suggest running a DIY write-up on it for anyone else who might want to.
John M Feb 19, 2010 10:49 AM
Already done it -- not working well yet. I need to try a resistor like HID setups use but haven't had a chance.
https://dodgeforum.com/forum/3rd-gen...s-at-once.html
BadHab1t Feb 19, 2010 02:47 PM
refer to other thread ...you shouldnt double thread buddy....i know your a newb but ...the mods will prolly combine these....g.l with issue...
dodgewhiteout Feb 20, 2010 08:58 AM
alright jusjay i tried to find it b4 i posted this thread..otherwise i wouldnt have posted it. am i right?? and instead of tellin me not to "re thread" why didnt you refer me to the thread that would tell me how to do this?? i know that i am a "newb" but you must be some kinda veteran if you got time to look at this thread and then go find a different one that answers my question and then come back to mine to tell me im rethreading..
Thanks to everyone else that posted on my thread that couldnt find out how to do this either.
John M Feb 20, 2010 02:35 PM
I posted a link right above his post. I'll be glad to give you the exact wiring to do just so you can go do it and have it not work for you too.
I do get all 4 beams on high. If you want to do it before I figure out the LAMP OUT issue, be my guest.
dodgewhiteout Feb 20, 2010 07:46 PM
i would love a diagram on how to do this. but i think that there is a problem...my truck is a 08 and i cant find any kinda headlight relay anywhere. the only fuse block that i can find is under the hood is there one in the cab that i am overlooking? i looked in the owners manual as well and the only fuse block that it directed me to was the one under the hood
John M Feb 21, 2010 04:43 PM
There's nothing to do with the stock relays (if you could find any; I couldn't either).
You've got to add a relay at each headlight housing. Wire it like this:
http://moojohn.com/truck/all4.gif
You must use relays with the center pin.
1) Cut the low beam wire and attach the supply (from the truck) to pin 87a and the other end (to the light) to pin 30.
2) Tee off of the high beam's positive wire and attach it to both pin 85 and 87.
3) Tee off of the ground wire and attach it to pin 86.
All wiring is done between the new headlight and its harness, meaning you don't touch the truck's wiring at all.
This leaves you with stock low beams and all four for high beam. Unfortunately the truck senses zero load on the low side while the relays are on high beam, meaning it triggers the LAMP OUT light & dinger every time you go back to low beam. Mine also does it when I crank the truck without the lights on at all.
OklaHemi Feb 21, 2010 05:48 PM
hmmm i havent seen this but i do have my fogs wired to stay on when i flip my brights and my hellas on a seperate switch to be extra bright. is there any chance of this burning up the factory components? i dont know alot about wiring but some people have posed the question in the past and it never got asked. good luck on it and take some pics
RedTruck-VA Feb 21, 2010 06:00 PM
John,
Nicely done, much better than what I came up with.
© 2026 MH Sub I, LLC dba Internet Brands
