This may be a dumb question.
The use of aluminum cylinder blocks, cylinder
heads, and water pumps requires special corrosion
protection. Mopar
protection. Mopar
t Antifreeze/Coolant, 5
Year/100,000 Mile Formula (MS-9769), or the equivalent
ethylene glycol base coolant with organic corrosion
inhibitors (called HOAT, for Hybrid Organic
Additive Technology) is recommended. This coolant
offers the best engine cooling without corrosion when
mixed with 50% Ethylene Glycol and 50% distilled
water to obtain a freeze point of -37°C (-35°F). If it
loses color or becomes contaminated, drain, flush,
and replace with fresh properly mixed coolant solution.
