3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
ive heard of swapping gears when you lift a truck and add bigger wheels/tires.
example:
if you have 33"tires you should have 4.10 gears
" " " 35" " " " 4.56 gears
" " " 37 or 38 4.88 gears
well my question is if you have 22 -24 inch rims does the sam rule apply?
Need to figure out what the total diameter is. To get an idea go to tirerack.com and look at thier tires and all the specs. You can have a 31" tire on a 15" rim and it is the same as a 31" tire on a 17" rim and so on.
