need help ASAP
need help ASAP
guys i need some measurments . im getting ready for a brush guard but the one i found is for a 04-06 ram 2500 . so my question is for you 2500 guys what is the measurment you all have from the inside where the bumper mounts ,the 2 holes are for bar mounts go. i need the measurment from hole to hole . i want to make sure its the same as the 07. im talking from left 2 holes to right 2 holes . im showing 32 inches. so if a 04-06 is 32 inches im set ..
also what do you 1500 guys measure . ??
hear is a ruff pic to show where im talking ...also does yours look like this ??
as you can see the holes are right behind the air dam .
Trending Topics
Sorry man didn't really understand the question in the PM. Mine is an '06 and it measures 32 1/8" wide from center to center and 3 1/16" from top hole to bottom. There should be enough play in the bolt holes that you have no problem making it work. And the 1500 4x2 looks totally different. Hope that helps.
P.S. And yes, that is where the factory tow hooks are mounted.
