engine tick...not on a hemi?
Ill start off by saying that my truck does not have a hemi. So lately if I get in my truck when its been sitting for a few hours I hear a tick, and it gets louder with rpm. However the tick goes away as it nears operating temperature, usually above 160*F. I dont know if it could be a leaky manifold, a valve cover gasket, or something else. Any help or ideas would be greatly appreciated! And please no "use the search"comments, I only found one non-hemi related tick thread. Thanks again! *edit* I discovered this sound when I removed my cutouts. I couldnt hear it before so it may have been making this sound for a while now.
^^ what he said, I was thinkin maybe a bolt's loose and when the manifold heats up and expands it fills the gap and the leak stops? idk it's a possibility at least?
Weed you are the man!!! the last bolt closest to the cab on the manifold is snapped in the block. Im gonna make the stealership fix it. I have a life time warranty
Trending Topics
Thats how mine was also. The exact same one. Luckily I could easier turn it out with pliers although I was prepared to reverse thread it.
