Permatex RTV sealant
Old 04-13-2011, 01:11 PM
Lowrider82's Avatar
Lowrider82
Lowrider82 is offline
Default Permatex RTV sealant
Black or Ultra Blue? Going to do the rear differential. The ultra states rear differential on there site the black doesnt. But I here alot of people use the black. I have some black in the garage will it work or should I drive to the store and get the ultra blue?
Old 04-13-2011, 01:18 PM
JDG103's Avatar
JDG103
JDG103 is offline
use the black
Old 04-13-2011, 02:52 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Black is supposed to be oil resistant I think
Old 04-13-2011, 03:59 PM
ramjamhemi's Avatar
ramjamhemi
ramjamhemi is offline
Did you mean Ultra Black, or just Black? The black's are normally for repairing weatherstripping and the like, so stay away from those in this case.
Both are highly oil reisistant as well as sensor safe.
The red is for continous high temp use, not sensor safe, and not as oil resistant as the Ultra's.
I believe the difference between Ultra Black and Ultra Blue is that Ultra Blue is supposed to work better to bond to surfaces that are not completely clean of oil.
I've used both, as well as the red over the years for all sorts of gasket making and never had an isssue with leaks.
As long as you clean the flanges really well, use either one.
Old 04-13-2011, 06:31 PM
Lowrider82's Avatar
Lowrider82
Well since I had to run to get the oil anyway, I went and picked up the Ultra Blue. So far no leaks. I'll give it a few days to make sure, then I'll be worry free. Found a wire brush works better than a scraper to clean the surfaces. Tried a gasket remover but it didn't penetrate that well or it was just to old from being in the garage. Thing took almost 3 full quarts instead of the 2.45 it states in the Haynes Book. But money well spent since it still cost me about half. Alot of places wanted $100-$120
Old 04-14-2011, 10:07 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
I used this stuff I get from work and it will eat through a gasket or paint in no time. Just dont get it on any skin and it WILL burn
Old 04-14-2011, 12:11 PM
FireFighter's Avatar
FireFighter
FireFighter is offline
I have always used the blue and being ****...along with a gasket. Never a leak on any of my vehicles. And use the stuff Weed shows works great with minimal effort of a brush.
Old 04-14-2011, 12:29 PM
Lowrider82's Avatar
Lowrider82
Yep, I used to have some of that but I think autozone either was out or they don't carry it. Napa I know does for a fact but I didn't want to drive to get there. But for future reference the 3m stuff sucks big time. It's says silicone on the can but it didn't peneatrate the RTV at all.
Old 04-14-2011, 08:09 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
Black or ultra black on the rearend.
Old 04-14-2011, 11:58 PM
Bent's Avatar
Bent
Bent is offline
I haven't used it in automotive use yet, but Hylomar UniversalBlue is what I use to seal mating surfaces on cooling pumps for power transformers in the power utility industry.
Quick Reply: Permatex RTV sealant
