E-Brake Light Won't Turn On
So it has been a long time since I've posted up with an issue...
Truck details are in the signature. The "Brake" light that should go on when you push the Emergency Brake Pedal down does not light up when the E-Brake is engaged. I've verified that the E-Brake is in-fact engaging, so that's a plus, and I've also verified that the Light comes on during the "start-up" cycle (when I turn the engine on)... I haven't had a chance to really look at the e-brake pedal and see if it's something simple, but just as a back-up I wanted to see if anyone may have had the same issue, or may know what to look for specifically before I start diving into this to troubleshoot. |
Should be a switch at the pedal. Check that.
| All times are GMT -4. The time now is 02:40 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
