What brand oil?
What brand oil do you use and why? I have read numerous positive reviews on Royal Purple oil, oil filters and gear oil. Does anyone run Royal purple in their hemi? Im about to switch mine out to Royal purple and wanted to hear what everyone has had to say. Multiple race shops (Mopar & LS) say thats all they run in their motors. Stock and modded motors. It cleans out your motor better and runs smoother. Whats yall opinions?
Royal purple is overpriced and overhyped. Stick with whatever you have been using. If you want synthetic they are all about the same. Buy the cheapest unless you are racing.
I don't doubt that it's a superior quality oil, but as stated above, it's probably overkill for most people. I run RP in my front and rear end diffs, but it's because I know I'm a lot slacker about changing those out as often as maybe I would want to or should with more standard oils. When I had a Harley, I ran RP oil in the motor and gearcase because it definitely quietened down the noises coming from inside the works and made it shift smoother. But in all my 4 wheeled vehicles, I just run a good quality synthetic oil and change it on a specific schedule.
I do plan on having some motor work done in the future. Cam, headers, heads....ect and they say they put RP in all the vehicles because the motors simply run better with it. They also said if you have any aftermarket work done like I stated im going to do above you need to run it (what they said), I did change my oil today to RP. I did notice my throttle response and it seems like HP boosted a little. It normally doesnt do that when I get my oil changed but when i did it with the RP today it did for some reason.
I ran RP in my 04 hemi. The big thing I noticed was the hemi tick was quieter. RP is great oil. I putting it in my diesel tomorrow. IMO its worth the money. I work my truck hard, I want all the insurance I can get.
Pennzoil Hi-Mileage conventional here, both for the Ram and the C. Valvoline ATF+4 in the Ram's tranny. Mobile1 in the Ram's diff.
It may not be as noticeable with larger engines, but as I mentioned above, I definitely noticed that it made my Harley run smoother and quieter and shift more smoothly. I could probably see, as mentioned above, that it would quieten down the hemi tick as well. On a bike, we are talking about a couple quarts of the stuff - not that much more money. In a hemi, it's significantly more expensive so you just have to decide if worth it to you.
Originally Posted by 04HemiGreg
(Post 3231667)
Royal Purple is 11.99 a litre in Canada. I would pay 7 and change all day no complaints.
Originally Posted by Northern Goat
(Post 3235649)
Al. |
