DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   3rd Gen Ram Tech (https://dodgeforum.com/forum/3rd-gen-ram-tech-65/)
-   -   P2311 code won't go away (https://dodgeforum.com/forum/3rd-gen-ram-tech/390356-p2311-code-wont-go-away.html)
Jacob645 Sep 30, 2015 08:33 PM
I had a this code for ignition coil 4 insufficient ionization. I replaced the coil and all 16 freaking plugs. Well the CEL is still coming on when I take off from a stop, and most of the time when I turn and go. I've checked the wires and re-seated the wiring harnesses. Still happening. Any ideas?
p38251 Sep 30, 2015 10:55 PM
Disconnect battery. To reset pcm
Jacob645 Sep 30, 2015 11:47 PM
I may have been unclear. The light goes off at times, but keeps coming back. I've unhooked the battery and turned on the key for 30 seconds. No change. The p2311 code will still come up on the odometer with the key trick.
p38251 Oct 2, 2015 07:24 PM
Try swapping with another coil. See if the issue follows the coil. If not you know its a wiring issue. How old are the plug wires?
Jacob645 Oct 2, 2015 08:14 PM
There are no plug wires. It started misfiring and shaking with a flashing engine light today. Took it to dealership. All on cylinder 4.
p38251 Oct 2, 2015 08:54 PM
What engine?
Jacob645 Oct 2, 2015 09:00 PM
Originally Posted by p38251 (Post 3266298)
What engine?
5.7
2006 model truck
Prismatic Oct 3, 2015 06:04 AM
Originally Posted by Jacob645 (Post 3266301)
5.7
2006 model truck
You have 16 plugs and 8 coils. You've got a few wires.
Jacob645 Oct 3, 2015 07:00 AM
Well, there are no "plug wires." I've checked the coil wires, but found nothing.
Jacob645 Oct 5, 2015 10:39 PM
Took it to the dealer. They said it needs a new computer for $1,200. Has anyone had any luck with a rebuilt pcm?
© 2026 MH Sub I, LLC dba Internet Brands
