Here's where we're at
First let me say "Thank you" to all that responded to the spark plug question of which one, sure enough that's what was in there. (Champion copper core)1 hr. for even bank, and some 2-1/2 hrs. for the odd bank, what a pain that is, behind and next to the brake booster .....crazy. Noticed some of the secondary coils rusted and splitting apart, will check some junk yards on this. Got better MPG and clean throttle (no I didn't move the butterfly) seems to respond better to the foot. :icon_cool:
"Don't Dodge it RAM it"! |
Not gonna lie... spark plugs is something I will pay someone else to do on my truck. I'm not exactly the most mobile and flexible person, so I don't mind letting someone else crawl around in there. I do most everything else, myself, but fook spark plugs...
Originally Posted by Chet Ubetcha
(Post 3286612)
Haha, I'm paying a young skinny guy at work to do mine. If you have a lift you can take the front wheels off and the fender shields and get to them much easier, but even then my old shoulder joints start screaming murder. |
Come on really?
Air ratchet to remove coils & plugs and you're off to the races, or buy a cheap Chicago tool impact from harbor freight and use it with some extensions and a swivel and you won't spend barely any time bending over the engine. The part that takes the longest is gapping the plugs and making sure the wires are going to the correct coils. The brake booster side isn't as bad as some make it seem, use a few one inch extensions and once plug is removed you can pull the extensions & socket out, then use the old plug wire boot to pull the plug out of the tube. When you install the plugs use an old plug wire boot to install the plugs, then remove the rubber plug gripper out of your spark plug socket so it doesn't stick to the plug on install. I was able to use my air ratchet to easily do all of the plugs, and it made short work of coil removal as well. I'm really surprised people get intimidated by this job, I'd rather do plugs on a Hemi than screw around with a small block chevy or other engine that has plugs exposed to the elements where I have to bust my knuckles to get them out. |
Not intimidated, I am just an AK amp on the right side and have about 20% usage of my left leg. The spine doesn't rotate the way it used to anymore, either. My truck sits on a 3" body lift and 33" A/T tires. I pick my battles. Some things are just more trouble than they are worth to me.
Any more questions? |
(Post 3286707)
Any more questions? As for the rest of us we need to wipe the tears away and get r done :) I was born with a foot that needed 30 surgeries to straighten out and I get fatigued as well and have sore joints going up both legs from the bad alignment and I'm only 29, but my adrenaline & focus on a job keeps me from thinking about the pain and I only feel the pain once the job is over which is a small plus for me. |
| All times are GMT -4. The time now is 09:18 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
