3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Having issues finding out where noise is coming form in the front end. The differential is leaking and the driver side axle has play in it. Want to know if I should change the bearing in the differential to dix the problem. Also abs traction control light and ebs lights are all on. Has new front outer wheel bearings
