A new users technical questions.
Evening. So I've got some plans for the future while owning this truck and most of them are ambitious and I want to know if I can do them at all. Hopefully this is the right forum that as they're technical related. If there's existing posts please link me to them. Here's the list:
- Add auto-darkening mirror even if it did not come with it.
- Add ESP if it did not come with it. (This is less of a desire and more of just curiosity).
- Convert cloth seat to power.
- Change my electronic 4 position 4wd switch over to the 5 position automatic 4wd switch. (This is something I'd very much like to do)
2. IDK
3. Plug should be under the carpet
4. Unsure
4. Unsure
You don't want ESP it sucks on curvy roads and it's just one more thing to go bad. If you want to convert to the 5 position transfer case switch with the full time option you will have to swap the transfer case, which I also wouldn't recommend because the part time only transfer case you have now is stronger and more reliable due to less moving parts.
well thats fun since i think its open rear. Kinda expected it to be just a software related thing but it does make sense now. As for esp you have a point but the plow people leave snow in intersections or turns here and dont do the best of jobs. Is it possible to add or is it not without extra parts altho please do explain more how it sucks on curvy roads as im actually curious.
Trending Topics
If the esp thinks you are going around a curve to fast it will kill power to the engine, and you won't be able to accelerate out of the curve like you should, sometimes it can also cause it to pull to one side when it does this, it wouldn't be much help in the snow either. An open rear diff sucks also the most effective thing to do would be getting a good limited slip like a Detroit truetrac or Detroit locker if you need a full locker, it depends on what you use your truck for.
