Negative Offset Wheels and Tires that Stick out of Fender
Hello I am looking to "stance" my truck and get a negative offset rim and wide tire my truck is lifted two inches and I have almost a 34 inch tire on them now they just sit even with the fender. I was wondering how I will know if I will rub when my tires sit outside the fender.
Thank You
Mike
Thank You
Mike
Sorry, not true. Offset is not "calculated", it's the difference between the mounting surface of the hub and the center line of the wheel. Backspace DOES NOT affect how much tire is outside the fender. It only affects the inner clearance of suspension parts and the inside of the wheel.
You are correct on the definition of offset. However, you cannot change offset, without changing backspacing, given the same wheel width. (and of course, the reverse is also true.) If you have a 10 inch wide wheel, with 4 inches of backspacing, it is going to stick out further from the wheel well, than a 10" wide wheel with 5" inches of backspacing. Yes, offset will still be different in that case.
Are you bad at math?
Trending Topics
For the SAME wheel width, changing offset will change backspacing. And vice versa. It is more than possible to have two wheels with the same offset, but, different backspacing. Of course, that would also make them different widths as well.
While technically, yes, you can determine backspacing from offset, why not just go directly with the measurement that counts? Backspacing. Makes life much easier. It's also much more straightforward.
