Elusive front end pop
Old 07-20-2017, 11:28 AM
tlw1980's Avatar
tlw1980
tlw1980 is offline
Default Elusive front end pop
Hello everyone I have a 2004 Ram 1500 4X4 4.7 L. I have had a clunking noise in the front end and I have replaced the upper ball joints and control arms, the lower ball joints, and the sway bar links. The clunking has been reduced but it still happens when I turn and hit bumps at the same time. It's just one clunk and not highly concerning, just bugs me. Cv's seem to look good. I don't know whether to call it a clunk or a pop either. Truck drives like new. Any idears? Thanks
Old 07-20-2017, 07:51 PM
p38251's Avatar
p38251
p38251 is offline
Tie rods? Shocks?
Old 07-20-2017, 08:59 PM
tlw1980's Avatar
tlw1980
tlw1980 is offline
Yeah it drives well for a tie rod bit never thought of shock
Old 07-20-2017, 09:19 PM
p38251's Avatar
p38251
p38251 is offline
Driving well? Unfortunately is not a good check for loose front end parts.
Old 07-20-2017, 10:11 PM
tlw1980's Avatar
tlw1980
tlw1980 is offline
I thought with bad tie rods there would be other signs besides the occasional noise like play in steering for example. They're my next task anyway i suppose.
Old 07-21-2017, 10:03 PM
p38251's Avatar
p38251
p38251 is offline
Check them for play. If they are not loose, leave them.
Old 07-21-2017, 10:35 PM
aliaj00@gmail.com's Avatar
aliaj00@gmail.com
aliaj00@gmail.com is offline
He stated that he has replaced most of the things there so the reduction in noise is expected but obviously those were not the issue as he still has the pop noise.
in my IDEA, you already spend a lot to put the new things in there, don't let a bad part to consume those new parts and start again from scratch minus money. go under it and start looking for what you have not changed or how well you have mounted the parts you put there "torque specs on bolts/nuts" grease etc. for sure its something loose of worn out just eliminate whatever you can and what will remain is the cause . have someone to hear near the tire and replicate it to check the general area the sound comes from you, do it on low speed and listen to both sides etc.
regards,
TIM
Old 07-22-2017, 08:41 AM
tlw1980's Avatar
tlw1980
tlw1980 is offline
Thanks ya'll
