3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Just bought an 02 Ram 1500. ABS and brake lights were on. Fella I bought it from said he put a different rear end in it. He said he went from 4.10 to 3.9 and that is what's throwing the lights on. (Check engine too) Any way to turn the lights out without reprogramming the computer? He said he was told $700 to reprogram.
I would call the dealer, and see what they have to say. It is about 15 minutes worth of work, I can't believe they would want to charge that much money for it.
That makes your 4x4 useless. Instead of re-programming the PCM, I would look for another diff, with the right gears, or, re-gear the one that's in there. If you try and use 4x4 the way it is, stuff is going to blow up.
