Go Back  DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram Tech
Reload this Page >
A new users technical questions.
Old 10-17-2018, 06:16 PM
SnowBeast428
SnowBeast428 is offline
Default A new users technical questions.
Evening. So I've got some plans for the future while owning this truck and most of them are ambitious and I want to know if I can do them at all. Hopefully this is the right forum that as they're technical related. If there's existing posts please link me to them. Here's the list:
- Add auto-darkening mirror even if it did not come with it.
- Add ESP if it did not come with it. (This is less of a desire and more of just curiosity).
- Convert cloth seat to power.
- Change my electronic 4 position 4wd switch over to the 5 position automatic 4wd switch. (This is something I'd very much like to do)
Old 10-17-2018, 08:06 PM
MoparFanatic21
MoparFanatic21 is offline
1. So you have the overhead display? If so the wiring should be there for the mirror, if not you will either need to wire it in or get the whole harness.
2. IDK
3. Plug should be under the carpet
4. Unsure
Old 10-17-2018, 08:56 PM
primem
primem is offline
what year is your truck. 3rd gen of different years can be networked differently.
Old 10-18-2018, 03:25 PM
SnowBeast428
2007 dodge ram 1500. I looked up front and I see electrical wires going to the wheel hubs so I'm guessing it has 4 wheel ABS. would make sense as it used to be an enterprise truck.
Old 10-18-2018, 03:45 PM
00t444e's Avatar
00t444e
00t444e is offline
You don't want ESP it sucks on curvy roads and it's just one more thing to go bad. If you want to convert to the 5 position transfer case switch with the full time option you will have to swap the transfer case, which I also wouldn't recommend because the part time only transfer case you have now is stronger and more reliable due to less moving parts.
Old 10-18-2018, 03:52 PM
SnowBeast428
well thats fun since i think its open rear. Kinda expected it to be just a software related thing but it does make sense now. As for esp you have a point but the plow people leave snow in intersections or turns here and dont do the best of jobs. Is it possible to add or is it not without extra parts altho please do explain more how it sucks on curvy roads as im actually curious.
Old 10-18-2018, 04:03 PM
00t444e's Avatar
00t444e
00t444e is offline
If the esp thinks you are going around a curve to fast it will kill power to the engine, and you won't be able to accelerate out of the curve like you should, sometimes it can also cause it to pull to one side when it does this, it wouldn't be much help in the snow either. An open rear diff sucks also the most effective thing to do would be getting a good limited slip like a Detroit truetrac or Detroit locker if you need a full locker, it depends on what you use your truck for.
Old 10-18-2018, 04:20 PM
SnowBeast428
Guess I was misinformed that it was as good as i've heard. A truetrac would work as that's an LSD last i remember right? Also I'm looking to get a auto darkening rear view mirror. Should I get some generic one or should I try to find the right one for the year i have? I wouldn't know what part number i'm looking for however.
Old 10-18-2018, 06:00 PM
00t444e's Avatar
00t444e
00t444e is offline
A Truetrac is the best limited slip on the market in my opinion. I'm not sure about the mirror, but I think an after market one would probably be fine.
Old 10-19-2018, 12:41 AM
MoparFanatic21
An adtermarket one won't work unless it's a direct replacement and used the factory connector
Quick Reply: A new users technical questions.
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
