3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Throttle body, or throttle pedal position sensor.... Getting any codes?
Moving this to third gen ram section for ya. Welcome to DF!
no codes at all someone suggested change the fuel filter
so far we changed the crankshaft position sensor and the camshaft position sensor egr valve cleaned the tube clean the throttle body and its got a new thermostat
Possibly torque converter. Or the tcc spring in the transmission pump, they are known to break and will cause the tc to stay locked coming to a stop which kills the motor and then during take off it will feel like you have no power. Does the motor rev up during take off? How many miles on it and any work done recently?
so far we changed the crankshaft position sensor and the camshaft position sensor egr valve cleaned the tube clean the throttle body and its got a new thermostat 230k
