Help! 03' Dodge Ram 1500 5.7 hemi
Currently have some engine issues going on with my truck and I know it's probably seals going out. Before I take any steps I just would like to know for sure what is exactly going on.
Engine has 208654 miles on it. issues: burns oil and I have to top the oil every time I fill up on gas. when I first start the truck blue smoke comes out. it is now also idling fairly rough. When I come to hard stops it likes to shut down completely. Any helpful answers would would be greatly appreciated! Thanks all. |
Valve seals are likely a contributor, but, I would be tempted to do a compression test, and see what things look like.
For the stalling, disconnect the battery, remove, and thoroughly clean the throttle body. When is the last time you changed the plugs?? |
If the engine is burning oil, you'll want to run hotter plugs so they don't foul as fast.
