Dodge 1500 5.9 2002 turnover but want crank fuel and battery gauge don’t move
I was at one point able to wiggle the bottom pin 3rd pin on computer would make the guages to fuel and battery move then it would crank wiggles wires and heard a clicking sound sounds like under fuse box that lasted for two minutes now it want start and guages want move at all. 2002 Dodge Ram 1500 5.9
Yes all the lights come on when ignition is turned on but the oil gauge temperature gauge don’t work battery gauge don’t work fuel gauge don’t work but lights come on when first turn key on so just guages don’t work when I would wiggle the wires before the clicking guages would work then truck would crank
Trending Topics
Most of them are going to be voltage out to various sensors, wires for the return signal, and grounds. PCM only gets power on a couple wires. You really need a wiring diagram......
If all the pins look good, are clean, and making good connection...... time to start looking elsewhere. Unfortunately, the way dodge wired these trucks, if ONE 5 volt sensor fails in a particular fashion, it takes down the whole 5 volt bus, including the communications bus..... So, very little works.
Fixed
Sent computer off to person on eBay they fixed it sent it back in two days truck crank right up haven’t drove have to get insurance back inspected and test out but believe it’s fixed soon as plugged it up gauges started working I knew that was it!!! A year later and 100$ not bad I really thought it was wiring tho talk to a mechanic and he told me computer that they sucked in these trucks that’s what made me send it glad I did.
