2004 3.7 Dakota, No bus no crank
The truck randomly shut off as I was driving.
- No gauges work - No bus on odometer - Does not crank - I've checked all fuses and relays, starter cranks if relay is jumped, fuel pump works if relay is jumped, jumping the ASD does nothing. replaced camshaft postion sensor. - all grounds on PCM pins get 12v - unplugged Crank, Cam, MAP, TPS, Oil presure sensors, made no difference. Cam plug outer pins get 5v, 4.90-5v, middle ground pin gets 12v I get the same voltages for Crank, TPS sensors. I could get the MAP sensor off, it looks melted, so i cut the wires, still no bus no crank. MAP wires get 5v, 12v ground, 4.90-5v signal. |
12 volts on that ground pin ain't right. Need to find out why.
Problem solved.
PIN 11 FUSED IGNITION SWITCH OUTPUT PIN 12 FUSED IGNITION SWITCH OUTPUT (OFF-RUN-START) on PCM C1 plug both pins should get 12v with key on position, my pin 11 was not getting 12v, so i cut the wire and jumped 12v to it.Truck started and no bus is gone. |
(Post 3458877)
Hahaha, or hack the harness and tie it directly to the battery and let the next owner wonder why :D |
