I might chicken out!
RE: I might chicken out!
I wanted to do the exact same thing, but I was also worried about Johny Law. Check out the LED tail lights on Ebay. I just installed a set on my truck and they include reflectors built in and you don't have to wire resistors in to stop the "bulb out" light and a DOT stamp of approval molded into the lens. I paid $180 shipped, but they should continue to come down in price (used to be $300 a few months ago).
ROFL!!!!
And the officers responce would be: "Sure son....just jump into the back of my cruiser here...and you can enjoy mine!!!"
Being that doing 80 in a 35 zone would probably get yr license suspended:|:|:|:|:| But you could try it
No. Hazards=stock hazards. As in the turn signal and hazard combo. Only the rear hazards can be red! which is how i got around putting the strobes just above my brake lights
ORIGINAL: rob[GL]
The only thing I don't like about our trucks... I *HATE* that the brake lights, AND the turn signals are red...
Every other manufacturer uses yellow turn signals, and I think that makes much more sense...
It has been scientifically proven, that the human eye does not react as fast to the color red, as it does to other colors... I know many times, I have found myself questioning whether a person is turning, or they simply suck at using their brakes...
Personally, I plan to replace my turn signal bulb with a different color. If every other car on the street has yellow turn signals, I don't see how it could possibly be illegal for me to change my color.
I'm trying to come up with a way to make the lights on my 03 conform.
The way we do it here, is to junk the clear reverse lights and instal some yellow bulbs. Tie into the turn circuit and then install a new reversing light.
We also have to have a rear red fog light with a warning light on the dash, to let you know it's in the switched on position.
It's a lot of work ............but hey...................my Dodge is worth it
ORIGINAL: rob[GL]
ORIGINAL: rob[GL]
Anyways, for the guy in the UK...
Could you not just stick a Green bulb into the blinker spot? A green bulb emitting light through the red plastic tail light cover... Should make a Yellow appearance, should it not?
He he he...................basic physics.
I never gave that a thought. I last studied that back in the day ha ha ha.
Just looked on the web and found this.........http://www.bway.net/~jscruggs/add.html
It's worth buying a Green bulb or painting a clear one eh?
I'll try it and post a reply.
Thanks so much for what could be a very easy, fast and effective fix.
Cheers.
Al.
