2004 TSB's for Ram 1500
Make : DODGE Model : RAM 1500 Year : 2004
Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 2304605 Date of Bulletin: OCT 01, 2005 NHTSA Item Number: 10017637 Component: STRUCTURE:BODY Summary: WATER LEAK AT ROOF MOUNTED MARKER LAMPS. *SC Check to Request Research. Submit below. Make : DODGE Model : RAM 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 2401305 Date of Bulletin: AUG 04, 2005 NHTSA Item Number: 10016603 Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER Summary: AIR CONDITIONING (A/C) COOLING COIL ODOR. *TT Check to Request Research. Submit below. Make : DODGE Model : RAM 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 05002 Date of Bulletin: APR 28, 2005 NHTSA Item Number: 10015075 Component: ENGINE AND ENGINE COOLING Summary: NEW WATER PUMP FOR 3.7L ENGINE - NO LONGER COMMON WITH 4.7L. ADVANCED SERVICE INFORMATION #05-002. *TT Check to Request Research. Submit below. Make : DODGE Model : RAM 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 1801705 Date of Bulletin: APR 21, 2005 NHTSA Item Number: 10015060 Component: ENGINE AND ENGINE COOLING Summary: LONG CRANK TIMES IN AMBIENT TEMPERATURES BELOW FREEZING. *TT Check to Request Research. Submit below. Make : DODGE Model : RAM 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 1801305 Date of Bulletin: APR 19, 2005 NHTSA Item Number: 10015058 Component: ENGINE AND ENGINE COOLING Summary: IDLE FLUCTUATION/DIAGNOSTIC TROUBLE CODES. *TT Check to Request Research. Submit below. Make : DODGE Model : RAM 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 1801605 Date of Bulletin: APR 12, 2005 NHTSA Item Number: 10015068 Component: VEHICLE SPEED CONTROL Summary: THROTTLE BODY COKING. *TT Check to Request Research. Submit below. Make : DODGE Model : RAM 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : E09 Date of Bulletin: APR 01, 2005 NHTSA Item Number: 10015067 Component: EQUIPMENT:OTHER:LABELS Summary: EMISSIONS RECALL E09 - NEW VECI LABELS. *TT Check to Request Research. Submit below. Make : DODGE Model : RAM 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 1804104 Date of Bulletin: OCT 25, 2004 NHTSA Item Number: 10010536 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: IMPROVED AUTOMATIC TRANSMISSION SHIFTING IN TOW/HAUL MODE. *EH Check to Request Research. Submit below. Make : DODGE Model : RAM 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 42 Date of Bulletin: OCT 01, 2004 NHTSA Item Number: 10010563 Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM) Summary: EMISSIONS RECALL D42. REPROGRAM PCM - OBD CALIBRATION. THE POWERTRAIN CONTROL MODULE (PCM) WAS INADVERTENTLY PROGRAMMED WITH INCORRECT SOFTWARE. THIS CAN CAUSE THE ON-BOARD DIAGNOSTIC (OBD) SYSTEM TO MALFUNCTION. *TT Check to Request Research. Submit below. Make : DODGE Model : RAM 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 1803704 Date of Bulletin: SEP 27, 2004 NHTSA Item Number: 10010488 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: FUEL ECONOMY IMPROVEMENT, WHITE SMOKE ON START UP, ACCURACY OF FUEL MILEAGE IN OVERHEAD CONSOLE DISPLAY. FLASH. *TT Check to Request Research. Submit below. Make : DODGE Model : RAM 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 0311 Date of Bulletin: NOV 25, 2003 NHTSA Item Number: 10006305 Component: ELECTRICAL SYSTEM Summary: RECOMMENDED 12V SWITCHED ACCESSORY SOURCES. THIS IS A FISHER SERVICE BULLETIN. *MR Check to Request Research. Submit below. Make : DODGE Model : RAM 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 03014 Date of Bulletin: AUG 29, 2003 NHTSA Item Number: 10003520 Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM) Summary: SERVICE ACTION 03014 - POWERTRAIN CONTROL MODULE (PCM) ELECTRICAL CONNECTOR SEAL INSPECTION/REPAIR PROCEDURE. *TT |
RE: 2004 TSB's for Ram 1500
Missed one
Make : DODGE Model : 1500 Year : 2004 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 0500105 Date of Bulletin: JAN 06, 2005 NHTSA Item Number: 10012317 Component: SERVICE BRAKES, HYDRAULIC Summary: BRAKE SHUDDER OR VIBRATION. *EH |
I'm a little confused, are these possible problems with the 04 1500's or are they recalls?
They are techinical service bulletins for the 2004 Dodge Ram 1500. They are issued by Dahmler-Chrysler to instruct dealerships how to correct potential problems. They are not recalls.
http://www.nhtsa.dot.gov |
There's also a link above in the header with them as well.
| All times are GMT -4. The time now is 04:22 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
