Error Code- P0441 Evaporative Emission Control System Incorrect Purge Flow
Error Code - P0441
Just had this come up on my 03 Hemi. On mine it was the two large hoses that connect to the cannister and they were missing hose clamps and were not fully seated. I installed clamps and cleared the error code with my scanner and drove the truck today with no errors coming up.
If you get under the truck and look at the cannister from the passenger side view, you can get your hands in there and tighten a clamp on them if that is the problem in your case.
Joe
Joe
Just had this come up on my 03 Hemi. On mine it was the two large hoses that connect to the cannister and they were missing hose clamps and were not fully seated. I installed clamps and cleared the error code with my scanner and drove the truck today with no errors coming up.Joe
Had this issue a while ago and it just came back. Last time replaced the evap solenoid and the evap canister. The canister had deteriorated and was spilling charcoal into the lines. The solenoid was stuck open and likely had a chunk of charcoal stuck in there somewhere. Tried to clean solenoid with compressed air, but that didn't help. Blew out all the lines before installing new components. That fixed lasted 3 years.
Recently I had to install new rear leaf springs and had to move the fuel tank to rear the front driver leaf bolt. I'm wondering whether shifting the tank slightly caused some fuel system line to be loose resulting in the P0441 code. I cleared the code and was good for a few weeks and came back today. Now I'll dig into the search for the source. Any ideas besides checking the solenoid and lines?
