4WD question about new 1500's
Old Mar 1, 2007 | 09:07 PM
ramquestion's Avatar
ramquestion
Default 4WD question about new 1500's
Does the new ram still offer full time 4wd or does it just offer part-time systems now. I went to tech specs on the dodge site and it only seems to list 4wd-PT but there site suggests an AWD setting and a part time setting (assuming it just locks the center diff if there is one). I find it conflicting that they say both part time and full time since really its either full time with a lockable center or just part time. My question is which is it? Does it have a center differential on the 07's? Ask Dr Z never replied over a week ago.
Old Mar 1, 2007 | 10:00 PM
kpj5br's Avatar
kpj5br
Default RE: 4WD question about new 1500's
My '06 does have an "A" setting, but it does not stand for All Wheel Drive, it stands for Automatic Four Wheel drive. It has a transfer case and two differentials. The A-4WD setting is meant as a convience, in that when it senses the need, it will shift to 4H automatically.
I know that doesn't answer your question conclusively, as I have no idea if they have an actual AWD system on hte market, but I do believe what the website is referring to is this Automatic setup.
Old Mar 1, 2007 | 11:39 PM
djr04's Avatar
djr04
I know of an 04 hemi laramie that had awd, but I think now dodge just offers the automatic part time in some models, along with the full time 4wd and 4low.
Old Mar 1, 2007 | 11:53 PM
hemiman123456's Avatar
hemiman123456
why dont they just make it 2wd, 4hi and 4lo, none of this part time or awd stuff,,,,less stuff that could break and cost u a lot of money
Old Mar 2, 2007 | 02:54 AM
ramquestion
I should have posted better links.
http://www.dodge.com/en/ram_1500/fea...apability.html
this link is what confused me. If you look under the transfer case section it says "all wheel drive", but could they just be refering to auto 4wd? To make matters worse it says part time 4wd also in the little display that pops up but the image dosen't change from the awd one...
Old Mar 2, 2007 | 03:58 AM
kpj5br's Avatar
kpj5br
Interesting link I hadn't seen that before.
Requires a little more research now I think!
In the meantime, here is a pretty good read on the subject (also look at the tables towards the bottom for 4WD type in various vehicles (including Ram):
http://en.wikipedia.org/wiki/Four-wheel_drive
Old Mar 2, 2007 | 04:00 AM
kpj5br's Avatar
kpj5br
And this explains the rest:
http://www.internetautoguide.com/rev...007/index.html
The part where they talk about the center differential (which it has) is about half-way down.
Old Mar 3, 2007 | 08:14 PM
ramquestion
Thanks everybody, turns out everyone was right! There are multiple 4wd systems offered. And big thanks to kbj solving the mystery! I am reprinting select quotes from the above link posted by kbj:
"For 2007, it's available with FFV capability (flexible-fuel vehicle), allowing the option of running on standard gasoline or E-85 ethanol. Full-time four-wheel drive (all-wheel drive) is available with the 4.7-liter V8 for improved stability in slippery conditions."
"Four-wheel-drive models use a part-time transfer case that can be shifted electrically from two-wheel drive without stopping. Shifting into 4WD High locks the center differential. Shifting down to low range provides superior traction in extreme conditions. The front axle driveshaft is automatically disengaged when operating in two-wheel drive. This minimizes the front-drive system's energy consumption and improves fuel economy."
"A full-time four-wheel-drive system is also available. Under normal driving conditions, the full-time system delivers 48 percent of the torque to the front wheels and 52 percent to the rear wheels. It's an excellent choice for icy conditions, gravel roads, or any situation that presents inconsistent grip. This system includes a locking transfer case that features 4WD High and Low modes.
A limited-slip rear differential is available and we recommend it for drivers who intend to go off road. A Protection Group includes tow hooks plus skid plates for the front suspension and transfer case. Automatics are available with a 3.55 axle ratio, or a 3.92 ratio, the latter better for towing and off-road driving. Some manual transmission models come with a 3.21 ratio for maximum economy. "
In summery both part time and full time systems are available. To my knowledge this makes ram the only full size 1/2ton truck available with a full time 4wd system. This is very good if you live in snow or heavy rain areas. Thanks again all.
Old Mar 3, 2007 | 11:05 PM
kpj5br's Avatar
kpj5br
ramquestion, my pleasure, as your question prompted me to search for the real info, and it was very enlightening to read all of that. Thanks to you for actually following and reading the links!
Old Mar 4, 2007 | 12:08 AM
squirtbottle09's Avatar
squirtbottle09
Is AWD availiable with the cummins?
