Finally got my EFAN installed.
Old Oct 7, 2009 | 05:04 PM
WWJD's Avatar
WWJD
Default Finally got my EFAN installed.
Well I finally got it all done and it's time to make a thread about it.
1. I started by loosening the clutch fan. This was ****ing hard and
i had to make something to hold the pulley in place. I took some metal and drilled some holes that lined up with the screw that pokes out on the motor and two holes on the pulley. PITA!
2.The I tracked down all of the bolts and connectors holding the shroud and connecting pieces together. I thought I was in the clear but I missed the two hoses on the bottom of the shroud connected by a clip.
3.after everything was ready to go I removed the clutch fan and fan shroud at the samer time.
4.Removed the air filter box. I actually already had it off from when I cleaned the throttle body. For this you really only have to take off the box with the filter in it.
5.Started making the brackets. Not really that easy but not to hard either unless you want them perfect. I didn't have a vise. I made them as best I could.
6.After the most fabrication with the brackets was all done I made sure of a good fit and went back to the shroud.
7.From the way the fan fit in the shroud I figured I would need to cut some shroud from the bottom. I wish I would have known this before I dropped the fan and shroud in the truck. I did it after I had everything in place. Gotta expect the unexpected with **** like this.
8.Mounted the fan up to the radiator and put the shroud back too. You have to put the fan and shroud in at the same time.
9.Started screwing screws and after a few minutes I had everything back together. I made sure all my wireing was right before this but still left everything hand tight JIC.
10.Wired up everything and put some "make it look nice" tubing to make it look stockish.. It's my first underhood work so it was hard to do a lot of stuff.
11. turned truck on and waited for it to warm up. Fan kept it right below the mid way point. Most of the radiator was cool to the touch. Just the four far corners were hot and the little radiator at the bottom was a little hot.(trans cooler?)
12. Havn't been able to test it on the road(dui) but I will at the end of the month when I get my DL back.
https://dodgeforum.com/forum/3rd-gen...-this-one.html
https://dodgeforum.com/forum/3rd-gen...c-fan-diy.html
http://www.mysporttrac.com/MySportTr...FanInstall.pdf
http://www.fordmuscle.com/archives/2...cfan/index.php
http://www.aaroncake.net/rx-7/efaninstall.htm
I say I am going to move this stuff.....I wouldn't mount the rlay or controller here again.
Had to cut some of the shroud so I used circle saws to get most of what I needed gone gone
space saver
MOUNT DAT!
Came out pretty nice though
Cutting on a budget
the first bend was easy
The fabricated tool to get the fan off.
One of the brackets in place
Old Oct 7, 2009 | 06:08 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
You will like the e-fan mod, probably the best mod I have done are far as a mpg improvement.
Old Oct 7, 2009 | 07:04 PM
chambers's Avatar
chambers
Yea it's a good mod and it's the only one that has given me any mpg gain on my truck.
Old Oct 7, 2009 | 07:20 PM
chefred112's Avatar
chefred112
I mounted my efan (Taurus efan) in the shroud itself so i wouldn't have to worry about any bracketry, also mounted my controller onto frame so that I couldn't see any wiring. Very good mod..welcome to the efan club..
Old Oct 7, 2009 | 07:36 PM
Off_Road_Teacher
They should think about putting e-fans in these trucks from the factory. My wife has a JGC with a Hemi and it came with an e-fan from the factory.
Old Oct 7, 2009 | 09:00 PM
oefootball_70's Avatar
oefootball_70
Any body know what an average 4.7 is seeing MPG increase from this mod?
Old Oct 8, 2009 | 03:40 AM
WWJD's Avatar
WWJD
I'm glad.
Old Oct 8, 2009 | 09:30 AM
HammerZ71's Avatar
HammerZ71
You sure that's an e-fan in her JGC? At first glance, I thought my JGC had an e-fan, but when I changed the oil in it the first time, I noticed two lines running to it from underneath.
It's a damn hydraulic fan!!! Or at least in my JGC Overland it is. Blew me away when I realized it.
Old Oct 8, 2009 | 09:41 AM
bwhite757's Avatar
bwhite757
This mod is definitely on my immediate to do list for my truck... Should've done it before I bought that cutout, oh well...
Good job man...
Old Oct 8, 2009 | 09:42 AM
Off_Road_Teacher
Now I am going to have to take a closer look. I never really examined the underneath of it, and I was just under there last week changing the oil.
