Flickering Lights?
So i just installed my new sound system in the truck, (self install, first time) 2 alpine type r 10" and a hifonix 1600watt mono amp.
I headed out on a drive tonight to massage my back and noticed my lights (dash & headlights) were flickering/dimming when the subs were being used most. When I turned it down a bit, via the amp remote, it stopped or was hardly noticeable.
I wasn't going crazy with the amp, the remote volume was maybe at 50%. I remember hearing about this before, but dont recall why it happens. None of previous car systems had this issue. So i'm assuming I did something wrong.
Any help?
power wire: 4gage
ground: 4gage
speaker wire: 10-12gage?
Any help?
power wire: 4gage
ground: 4gage
Most likely your power wire is too small along with the amps efficiency.
Your alternator is a 165amp so that's not an issue. My lights don't dim and I have a JBL/Crown BPX1100.1 1134wrms continuous and a JL450/4 which is 450w rms continuous. Lots of power and no dim. Both are class D and are very efficient.
I have 1/0ga Stinger Pro wire.
Most cheapo no name brands will claim 4ga and really be only 6 guage. You can get Kicker 4ga amp kits for $65 shipped off ebay.
When you try to pull too much current through a thin wire, you get a significant voltage drop and that causes tons of drain. Likely source of your lights dimming.
Waste of space and how often do you actually look at a cap?
At $40 for 2farad, that's $20 for each Farad. Most caps on the market are not as stated. Meaning they are smaller than 2farad most likely unless you got a name brand like RF?
Get yourself a Batcap HERE. The measurement scale is a little bit different, but it's equivelant to 100farad. 100farad at $140 is only $1.40 per farad. They will last longer than a cap as well. Most caps have a lifespan of 2-3years generally. Some last longer, but their power capacity is diminished. Same with this just like any battery, but it holds charges for loger and will last a bit longer.
Thanks for the help guys. I'm looking into that batcap now.
What do you mean by "the Big 3 upgrade"? Schwat is that?
I wants to see! lol
