I don't understand...
Old Jun 1, 2011 | 06:42 AM
devile's Avatar
devile
Can someone tell me if this truck has, EVIC, cruise control, trailer brake control, and remote start?
Standard Equipment
APAS Monotone Paint
BABS 160 Amp Alternator
BCVS 700 Amp Maintenance Free Battery
BNBS Electronic Stability Control
BRTS Anti-Lock 4-Wheel Disc Brakes
CE8S No Lumbar Adjust
CGDS Front Height Adjust Shoulder Belts
CGSS Supplemental Side Air Bags
CG3S Advanced Multistage Front Air Bags**
CKJS Black Vinyl Floor Covering
CSPS Driver/Passenger Assist Handles
CU3S Behind the Seat Storage / Bin
DH5S Elec Shift-on-the-Fly P/Time T/Case
DJMS 205MM HD Front Axle
DRNS 235MM REAR AXLE
DS7S Conventional Differential Frt Axle
GACS Tinted Glass Windows GJDS Rear Fixed Window
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach
JBFS Instrument Panel Black Bezel
JDCS 200 KPH Primary Speedometer J
HAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKYS Power Accessory Delay
LABS Tire Pressure Monitoring Warning LP
LCHS Rear Dome Lamp
LMAS Halogen Headlamps L
MGS Automatic Headlamps
LMKS Daytime Running Headlamps, High Beam
LPES Cargo and CHIMSL Lamp
MDAS Front License Plate Bracket
MENS Front Wheel Spats
MGAS Ram's Head Badge
MHLS MOPAR Rear Wheel Well Liners
MNAS Black Door Handles
MPPS Rear Wheel Spats
MS2S Ram 1500 Badge
MUSS 4X4 Badge MXCS Front Bumper Sight Shields
NFWS 26 Gallon Fuel Tank
NHKS Engine Block Heater
QBSS Deep Water Blue Pearl Coat
RCGS 6 Speakers
RESS Media Center 130 CD/MP3
SBAS Power Rack and Pinion Steering
SCFS 4-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHFS Rear Stabilizer Bar
SUAS Tilt Steering Column
TBMS Tire Carrier Winch
WF1S 17 Steel Spare Wheel
XA8S Non Adjustable Pedals
XBSS Pickup Box
XFKS 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XJJS Locking Tailgate
XJ8S Body Color Fuel Filler Door
X81S Instrument Panel Parts Module
X82S Door Parts Module
X83S Front End Parts Module
X88S Tire Wheel Parts Module
YACS Build To Canada Mkt. Specifications
Z6AS GVW Rating - 6350#
1ABS Canada Dealer Retail
125S Zone 25-Canada-Alberta
5BAS DS/6322 Vehicle Family
5I4S Four Wheel Drive (4WD)/(4X4)
5I7S Price Class L
5UGS 2011 Vehicle Specifications
5ZES 6 FT. Cargo Box
5ZJS Regular Cab
5ZLS 1500 Series
594S Vehicle Order Tracking
6CSS Canada Specifications Label
678S Alberta Province Code
Optional Equipment
Code Description Code Description Code Description
*TX HD Vinyl 40/20/40 Split Bench Seat
-V3 Dark Slate/Medium Graystone
AGDP RAM 1500 Express
AJH Power and Remote Entry Group
CBEP 40/20/40 Split Bench Seat
CBWP Highline Door Trim Panel
Options Report
CJ4P Supp Side Curtain Front Air Bags
DBAC All Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DMH 3.92 Rear Axle Ratio
DSA Anti-Spin Differential Rear Axle
EZH 5.7L V8 HEMI MDS VVT Engine
GNKP Rear View Auto Dim Mirror
GT6P Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMP Remote Keyless Entry
JPBP Power Locks
JPYP Pwr Windows, Front 1-Touch Down
JP8P Manual Adjust Seats
LE4P Black Exterior Mirrors
LNJP Fog Lamps
MBPP Body Color Front Fascia
MBQP Body Color Rear Bumper w/Step Pads
MFTP Body Color Grille
MW5P Hemi Badge NAA Federal Emissions
NERP Dual Rear Exhaust
NHDP Heavy Duty Transmission Oil Cooler
NHJP Exterior Mirrors w/Heating Element
NHNP Electronically Controlled Throttle
NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PBS Deep Water Blue Pearl Coat
RAAC All Radio Equipped Vehicles
RDDP Fixed Long Mast Antenna
RSC SIRIUS Satellite Radio
RSP Uconnect Voice Command w/Bluetooth
RSUP Audio Jack Input for Mobile Devices
TBSP Full Size Temporary Use Spare Tire
TTJP P275/60R20 BSW All Season Tires
TZAP Goodyear Brand Tires
WLZC All Aluminum Wheels
WMJP Center Hub
WPAP 20X8.0 Aluminum Wheels
XBNP Tip Start
XCMP Vendor Painted Cargo Box
XFH Class IV Receiver Hitch
XJCP Locking Lug Nuts
XLNP English/USA Language
YGVA 4.5 Additional Gallons of Gas
ZBUP Spring - Left Rear
ZFCP Spring - Left Front
ZPUP Spring - Right Rear
ZUBP Spring - Right Front
2TCA Customer Preferred Package 2TC
26C Customer Preferred Package 26C
4CPA Federal A/C Excise Tax
4H4 Special Scheduling Condition VII
4KZP 4X4 Tracking
4ZBP Vendor Painted Cargo Box Tracking
42EP Saltillo Truck Assembly Plant
I believe with the towing package, it included evic, as well with the Hemi, i believe it includes evic and speed control. However, I'm not sure and need some help.
Would also like some clarification as to the Customer Preferred Packages, 2TC, and 26C... what do they mean?
Old Jun 1, 2011 | 12:41 PM
frogslinger's Avatar
frogslinger
I am going with no, no and no... but then I am no expert.
Old Jun 8, 2011 | 01:43 PM
Palm's Avatar
Palm
What model truck is this? ST, SLT. SPORT, etc, etc.
