What's Oil Pressure supposed to be?
Hey guys, I notice on my analog gauge the oil pressure appears to be over half, but when you scroll through the evic, its only at 335 kpa or 49 psi....does that sound right?
Originally Posted by frofro666
(Post 1665792)
Yes, I think the pressure regulator must be set for 50 psi, as mine is almost always under that. About 25 psi when idling and fully warmed up.
Cool..thanks dudes.
Yep, mine sits around 49 once warmed up except when idling.
same here
Often times they program the cluster to keep the oil pressure needle more centered towards normal, if the computer detects oil pressure, because people would be calling dealerships like crazy when their needle reads low pressure once the engine is fully warmed up
| All times are GMT -4. The time now is 06:03 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
