Problem with the EVIC LCD Display
#21
Looks like that part lists for $229 (saw it for $153). That would be for the entire Speedo, Tach, EVIC cluster minus the front trim which has the lens. The entire unit has to be replaced as an assembly per the service manual which confirms what he was told by the dealer. Should be plug and play with no dealer service tool needed per the manual.
#22
finally got a chance to take a look at the setup options on the evic, and there is an option to turn off the "fuel saver" light in the menu for system setup. from what i can tell, my truck is hardly ever in fuel saver mode though, only when coasting from about 45 down to about 20, when i guess it kicks out of gear and idles the engine in V8 mode. this could explain why i'm not getting as good of mileage as everyone else. anyone else with the fuel saver light, when does it kick on for you, and what kind of mileage are you getting?
