Problem with 09 dodge ram 1500 in 4x4
Old 12-28-2010, 10:05 PM
denis1227's Avatar
denis1227
denis1227 is offline
Default Problem with 09 dodge ram 1500 in 4x4
Guys,
I have a 2009 dodge ram 1500. The other day I put into four wheel drive,I was doing approx 35mph. And I had a bad shimmey in the front end. Took it out ,put it back in and the same thing. Ihad it on the highway about 50-55 and was still there, but felt it less.
The only thing I had done to it since last year was put a 3" body lift on it.
I did have it out of four wheel during hunting season, and when I was making a hard turn I heard some loud clunking sound. But, in 2 wheel dr. I don't feel it.
Any suggestions b4 I take it in and have the service dept rape me?
Old 12-29-2010, 01:16 AM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
Moved this to the 4th gen section for you, get you the appropriate people helping you that way.
Old 12-29-2010, 04:03 AM
awful knawful's Avatar
awful knawful
awful knawful is offline
the clunking when turning sounds like a bad cv joint, which can cause the vibration also
Old 12-29-2010, 05:24 AM
TDTIPMO's Avatar
TDTIPMO
TDTIPMO is offline
35 seems kinda fast to me for shifting into 4x4. I don't like swicthing when I'm going over 25. Maybe I'm just over cautious. Either way, sounds like something mechanically wrong. Dealership shouldn't rape you though. It should be covered under warranty. I wouldn't worry about it. Let us know what you find out though.
Old 12-29-2010, 06:11 AM
zeek's Avatar
zeek
zeek is offline
do you have a leveling kit in it? if you do take it out, mine did the same thing. Also, the truck is under warrentee...take it back
Old 12-29-2010, 08:15 AM
Gary C.'s Avatar
Gary C.
Gary C. is offline
CV Joint(s)...
Old 12-29-2010, 12:28 PM
denis1227's Avatar
denis1227
I do have a leveling kit. It is out of warranty
Old 12-29-2010, 12:46 PM
denis1227's Avatar
denis1227
Anything they can do to keep it on?
Old 12-29-2010, 12:47 PM
jayman84's Avatar
jayman84
jayman84 is offline
most likely a cv joint. And that speed had nothing to do with the problem, you can shift these into 4wd at speeds up to like 50 mph so your good there.
Old 12-29-2010, 01:11 PM
denis1227's Avatar
denis1227
even with the leveling kit? Could the cv joint just cause trouble in four wheel drive and not two wheel.
Quick Reply: Problem with 09 dodge ram 1500 in 4x4
