Air Lift 1000's and spacer's
Old Jan 22, 2011 | 03:25 PM
pdavis53's Avatar
pdavis53
Default Air Lift 1000's and spacer's
For those of you that have Airlift 1000 bags did you install a spacer as well? I have a spacer from Top Gun Customz and the setup inside looks wierd. Basically the plactic puck on top of the bag is sitting against the spacer. It looks like it might be okay but I want to be sure. Is anyone else's setup like this? Do I need to decide if I want the spacer or the bag, can I have both?
Old Feb 8, 2011 | 11:13 PM
Lonecoyote69's Avatar
Lonecoyote69
Exclamation Taller Bags
Ask Airlift to change you out to the taller bags, they come with the narrow 1/2" nylon puck or filler block that fits snuggly inside the saddle boot of the coil. Still won't help the failing bag issues but keeps the bag centered better than the black 3" filler blocks.
