Do RRT's expire with basic warranty?
I called my dealer about my '09 with 65k miles to get RRT 11-019 performed for tailgate spoiler replacement and RRT 11-017 for broken exhaust manifold bolts. They basically said all RRTs that I was due had been performed and that RRT's expire with basic warranty. They will not perform those. I know my lifetime powertrain warranty should cover the bolts anyways, but are the lying to me?
I was told the same thing about my manifold bolts by my local dealer and didn't buy it, but they're also not the brightest bunch.. It took them 3 trips, a week and a half, a set of hub bearings and a new sway bar bushing to realize my squeak was just a loose shock tower. Gotta love warranty work.
RRT's?
Originally Posted by 70GS455
(Post 2955092)
Rapid Response Transmittal's are covered under the provisions of warranty. If the warranty is expired for the particular item then the RRT is not covered. Same with any TSB's (technical service bulletins) that may apply. |
NUMBER: 23-008-11 REV.A
GROUP: Body DATE: April 21, 2011 THIS BULLETIN SUPERSEDES SERVICE BULLETIN 23-008-11, DATED FEBRUARY 18, 2011, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE ADDITIONAL LABOR OPERATIONS. THIS SERVICE BULLETIN IS ALSO BEING RELEASED AS RAPID RESPONSE TRANSMITTAL 11-019. ALL APPLICABLE SOLD AND UN-SOLD VIN's HAVE BEEN LOADED. TO VERIFY THAT THIS SERVICE ACTION IS APPLICABLE TO THE VEHICLE, USE VIP OR PERFORM A VIN SEARCH IN TECHCONNECT. ALL REPAIRS ARE REIMBURSABLE WITHIN THE PROVISIONS OF WARRANTY. SUBJECT: Water And/Or Condensation In The Rearview Mirror Puddle Lamp And/Or Tailgate Spoiler Inspection OVERVIEW: This bulletin involves inspecting both rearview mirrors, tailgate spoiler and if necessary replace. MODELS: 2009 (DS) RAM 1500 Pickup SYMPTOM/CONDITION: The left and right rearview mirror puddle lamps may have water residual and/or will not illuminate. The customer may tear the spoiler off the tailgate when cargo is unloaded. |
It's surprising to me that if there is a known, identified, and documented defect that Dodge is unwilling to correct it given that it is out of warranty.
RRTs and TSBs are not the same as recalls. Recalls are usually safety related and are done, at the manufactures expense regardless of age and miles.
RRTs and TSBs are more for the dealership than the owner. They are basically telling the dealership if you see a vehicle with these symptoms, it is "likely" this, and this what you should do to correct it. They are to help prevent wasted time and resources diagnosing the same things over and over. Hopefully it happens under warranty, and it usually does. They don't issues these for 10 year old vehicles. If the warranty has expired, it is out of the owner's pocket. |
exaust bolts were covered on my truck out of normal warranty under the lifetime powertrain warranty
| All times are GMT -4. The time now is 02:33 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
