TMPS issues 2010 1500 sport
Old 08-08-2014, 02:48 PM
lukanov's Avatar
lukanov
lukanov is offline
Default TMPS issues 2010 1500 sport
So one day after putting my summer tires and rims on after winter my tmps light came on and starting beeping probably about once a minute, and so i checked my tire pressure display and it looks like its working and reading the tire pressures fine and then it freezes for a minute or so and then works again, all the while my "ding" goes everytime it freezes and unfreezes. ive done just about everything i can find
- checking tire pressures are correct
- disconnecting the battery and resetting system
- wrapping hid ballasts + ensuring my HID lights werent the problem
- ensuring my sensors all work properly and are in good condition
the dodge dealership told me they thought it was the irridium spark plugs i put in the truck, but i have a hard time believing that one.
so im at the point now where i tried to locate the actual door chime and put tape over it or something because driving in silence does not exist for me.
anyone have or heard of this issue?
Old 08-08-2014, 03:03 PM
oldjeep's Avatar
oldjeep
oldjeep is offline
If it happened after you switched wheels then doesn't that tell you there is a bad sensor ? Have you tried putting your winter wheels back on to see if it goes away?
Old 08-08-2014, 03:07 PM
lukanov's Avatar
lukanov
lukanov is offline
yea i did that immediately, but it looks like once the system got whatever error its getting it does not want to let it go for some reason
Old 08-08-2014, 05:21 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
HOLY HELL...what? lol
Under (or over) inflate about 10psi, drive it for a little while. Inflate them back to spec and drive it.
Old 08-08-2014, 05:34 PM
MoparMan1991's Avatar
MoparMan1991
MoparMan1991 is offline
Duct tape ought to clear that one right up!
Old 08-08-2014, 05:39 PM
TNtech's Avatar
TNtech
TNtech is offline
Ice Pic !
Old 08-08-2014, 06:14 PM
lukanov's Avatar
lukanov
lukanov is offline
ive tried the under/over inflation thing it still does not work does anyone know how to get at whatever is making the "bing" sound? if i could just tape over it to silence it until i figure out what the heck it is that would be fantastic
Old 08-08-2014, 07:31 PM
MoparMan1991
It's most likely inside the dash, so that probably won't be a feasible option.
Old 08-08-2014, 09:31 PM
lukanov's Avatar
lukanov
lukanov is offline
I am running out of ideas, I have researched this topic quite extensively on the internet and although I've come across some people having some TPMS issues with their ram any solution I try does not seem to work, looks like Ill have to figure this one out on my own seeing as how the dealership cant help me
Old 08-09-2014, 12:32 AM
SMGFATMAN71's Avatar
SMGFATMAN71
SMGFATMAN71 is offline
I had an issue with the tpms sensor not grounding on a moto metal wheel because of the finish, and they are mopar sensors. Other set of wheels and tires are on eagle alloy steel wheels,again mopar sensors, no problem.I like the eagles better anyhow.
Quick Reply: TMPS issues 2010 1500 sport
