DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   4th Gen Ram Tech (https://dodgeforum.com/forum/4th-gen-ram-tech-120/)
-   -   Key problem- can't start it (https://dodgeforum.com/forum/4th-gen-ram-tech/409023-key-problem-cant-start-it.html)
Martin Turcotte Nov 19, 2017 09:23 AM
I have a Dodge Ram 2016 slt crew cab.
Try to start it with my key ( do not have a push botton) d not start. Says the key is inside but I took it off and after, there's a fob message. Try my other key, still the same. Batteries of the keys are ok ( other function work) Can't close my powerlock from the door( won't work and says keys are inside) What sould I do to make it work?
thank you
706jim Nov 19, 2017 11:30 AM
Return it to your dealer for warranty repair.
TNtech Nov 19, 2017 12:45 PM
Why do you have a message about your FOB location if you don't have a push button. That makes no sense.
Those ignition nodes that you stick the key in are notorious for premature failure. When you turn the key to ON, does anything happen?
© 2026 MH Sub I, LLC dba Internet Brands
