305-50-20
Old 05-24-2019, 10:09 AM
bscill's Avatar
bscill
bscill is offline
Default 305-50-20
Will 305-50-20 fit on a stock 09 without rubbing or using any spacers?
Old 05-24-2019, 01:10 PM
SHO Rod's Avatar
SHO Rod
SHO Rod is offline
I won't have an answer for you, but in anticipation of someone who might, they will probably need clarification as to if you mean stock wheels or if you plan for aftermarket wheels with possibly a different offset. I'm unsure if by "stock" you just meant stock ride height, or with the stock wheels too.
-Rod
Old 05-30-2019, 07:26 AM
bscill's Avatar
bscill
bscill is offline
Stock ride height on the truck, and it will be aftermarket wheels. Sorry I didn't list that.
Old 05-30-2019, 07:33 AM
jkeaton is offline
Dodge Forum Administrator
Whats on the truck now? Need to provide as much info as possible.
Old 06-11-2019, 09:23 AM
bscill's Avatar
bscill
bscill is offline
srt10 22's is on the truck now, 285/45/22 with 1/4"spacers on the front cause of rub on the control arms
Old 06-11-2019, 02:01 PM
HeyYou is online now
Received 3,164 Likes on 2,918 Posts
The 305/20's are going to be almost an inch wider, so, get rims with the appropriate backspacing, and you should be fine.
Old 06-21-2019, 12:43 PM
jake whitebird's Avatar
jake whitebird
jake whitebird is offline
lets see pics of those 22s!!! that was to be my next post, 275-60-20 on the stock wheels now. 33' tall, 10.8" wide, and 6.5" sidewall. so id like to stay that height, but wouldnt mind just a tad wider. What are you guys running for rubber? 285/60/20? thatd be 33.5",11.2 wide, and 6.7" of sidewall! sorry to hijack lol
Quick Reply: 305-50-20
