2009-2012 Ram 1500 LED Upgrade Bulb Size Guide
Hello everyone, at Lasfit, we take into consideration the different generations and variations of the Ram 1500 when it comes to providing suitable LED bulbs. Whether you have the early years' models with 2 or 4 headlights or the 2009-2012 Ram 1500 with projector and reflector, Lasfit has you covered. You can easily find LED bulbs that are compatible with your Ram 1500, eliminating the hassle of searching for the right replacement for your original halogen bulbs.
If you own a 2009-2012 Ram 1500, LAplus offers a different headlight option. Additionally, you can use the T-3157D for the front turn signal of your 2009-2012 Ram 1500, which is not compatible with the 2013-2015 and 2016-2018 models. Thank you for following the Ram 1500 replacement guide. We appreciate your patience in reading it. Our goal is to provide a more convenient experience for changing the lights on your Ram 1500. If you have any thoughts or suggestions, please feel free to leave a comment below this post. The different trims of 2009-2012 Ram 1500 ● Ram 1500 with 2 headlights ● Ram 1500 with 4 headlights You can check more information about the compatible LED bulbs for 2009-2012 Ram 1500 from this page: http://www.lasfit.com/products/led-b...-2012-ram-1500 Product Spec for 2009-2012 Ram 1500 Low Beam: LAplus H11 High Beam: LAplus 9005 Headlights: LAplus H13 LAplus 9005/H11 for 2009-2012 Ram 1500 with 4 headlights LAplus H13 for 2009-2012 Ram 1500 with 2 headlights Each bulb in the LAplus series is meticulously engineered to deliver a robust 30W and 3000LM output, resulting in a remarkable brightness compared to factory halogen bulbs. These bulbs are specifically tailored to suit your 2009-2012 Ram 1500. With their radiant 6000K bright white light, you can enjoy exceptional visibility on even the darkest roads. The 360-degree adjustable socket allows for effortless customization of the beam pattern, ensuring optimal lighting performance according to your preferences. Furthermore, these bulbs are equipped with an interior driver and boast a compact size, guaranteeing. https://cimg8.ibsrv.net/gimg/dodgefo...4fb2ec10b2.png Fog Lights: LAplusH10 LAplus H10 for 2009-2012 Ram 1500 with 4 headlights LAplus fog lights offer 60W power and an ultra-high brightness of 6000LM. Its 6000K white light effectively penetrates rain, fog, and snow, allowing for clear visibility of road conditions in adverse weather. With no extra driver required, installation on the fog light housing is hassle-free. Additionally, the 360° adjustable booth ensures easy installation on the fog light housing. Please don't worry that the dim light will make you lose your direction, LAplus is definitely your best choice to replace the Ram 1500 fog lights. Other Front Exterior LED Lights Front Turn Signal Lights: T-3157D With 40 PCS upgraded 3030 SMD LED chips, T-3157D can provide up to 2600LM/bulb, which is extremely brighter than the halogen bulb. 360-degree illumination, no more worry about the dark spot. You can freely change the color from 3000K amber which is suitable for your turn signal light to 6000K Xenon white which can be installed as a parking light or daytime running light for your Ram 1500. https://cimg0.ibsrv.net/gimg/dodgefo...294179e2ff.png Rear Exterior LED Lights Backup Lights: L-T15 L-T15 for 2009-2012 Ram 1500 with 4 headlights L-T15 LED bulbs equipped with high-power 3030 SMD LED chips, each bulb can provide 700LM and 6000K pure white can let the rear vehicle notice you are reversing. Cargo Lights: L-T15 3rd Brake Lights: L-T15R(Red) The Lasfit L-T15 bulb is designed to provide a bright output of 1400LM per set, ensuring sufficient brightness to alert vehicles behind you. Moreover, you can rest assured about compatibility issues as it is canbus supported, reducing the hassle of flickering lights. License Plate Lights: L-T10 The L-T10 series features 3 bright 3030 lamp beads that can provide 800LM of brightness for the 2009-2012 Ram 1500. With its 6000K white light, it can effectively illuminate the rear license plate, ensuring clear visibility. The 360° lighting effect ensures that no area is left in darkness, providing ample lighting for vehicles approaching from the rear. https://cimg9.ibsrv.net/gimg/dodgefo...2bed96425c.png Interior LED Lights Map Lights: L-44MM The L-44MM festoon bulb from Lasfit is equipped with 8 3030 SMD LED chips, providing an extremely bright 6000K white light. It features an Efficient Aluminum Heatsink System, which enables the Ram 1500 to dissipate heat effectively, thereby extending the lifespan of the headlights. https://cimg9.ibsrv.net/gimg/dodgefo...9e6eaee46f.png Moreover, You can get... ● 45 Days Money-Back Guarantee Our return policy allows you to return your purchase within 45 days of the date of purchase for a full refund, no questions asked. We make the return process hassle-free by providing a return shipping label for your convenience. ● 1-Year Hassle-Free Warranty Lasfit provides a hassle-free return policy and warranty for 1 year. In the event of any quality issues, we offer an easy exchange or return with a provided return label. If you have any questions about the mentioned information, please leave a message in this forum. |
