2016-2018 Ram 2500 3500 LED Upgrade Bulb Size Guide
Hello everyone!
Lasfit LAplus series continues to offer a stunning array of headlights that will perfectly complement your Ram 2500/3500 truck, providing enhanced visibility and safety on the road. What's more, for those of you driving the 2016-2018 models, we have standard sockets available for your turn signal lights, ensuring a seamless fit with your vehicle's existing setup. But that's not all! We understand the importance of well-lit interiors, which is why we've expanded our range of LED bulbs to include map lights and dome lights compatible with Ram 2500/3500 trucks from 2016 to 2018. Now, you can effortlessly elevate the interior lighting of your beloved Ram, adding a touch of luxury and functionality to your driving experience. The different combo pack for 2016-2018 Ram 2500/3500 ● Ram 2500/3500 with projector https://cimg3.ibsrv.net/gimg/dodgefo...2f17d947c8.png ● Ram 2500/3500 with reflector https://cimg4.ibsrv.net/gimg/dodgefo...db591e512a.png Product Spec Low Beam: LAplus H11/9005 LAplus 9005 for Ram 2500/3500 with projector LAplus H11 for Ram 2500/3500 with reflector High Beam: LAplus 9005 Each bulb in the LAplus H11 or 9005 series is specifically designed to provide a powerful 30W and 3000LM output, delivering a brightness that is exceedingly brighter than traditional halogen bulbs, perfect for your 2016-2018 Ram 2500/3500. With a thinner 2.00MM copper substrate and a 360-degree adjustable socket, you have the freedom to customize the beam pattern to your liking. The LAplus series also features a cold-pressed aluminum body and dual ball-bearing fan, ensuring efficient heat dissipation for enhanced performance. Imagine driving your Ram 2500/3500 down a country lane, worry-free of dim and dark visibility, thanks to the Lasfit LED bulbs. Experience superior lighting like never before! https://cimg5.ibsrv.net/gimg/dodgefo...9a9c730963.png https://cimg7.ibsrv.net/gimg/dodgefo...34429e5d8d.png Other Front Exterior LED Lights Front Turn Signal Lights: T-3157D Each bulb features 40PCS upgraded 3030 SMD LED chips (30PCS Amber + 10PCS White), delivering a bright and powerful 2800LM output with 28W. Perfect for your turn signal lights, these bulbs provide exceptional brightness that ensures other drivers easily notice your sign. Say goodbye to the worry of dim factory lights that may cause pedestrians or other vehicles to miss your turn signals. The upgraded decoding system reduces annoying flickering, providing a stable and consistent light output. The T-3157D bulbs also offer a convenient switchback function for your 2016-2018 Ram 2500/3500. With simple control, you can get 3000K amber for turn signals to 6000K white for daytime running lights or parking lights. https://cimg1.ibsrv.net/gimg/dodgefo...0f5f3693c6.png Rear Exterior LED Lights Rear Turn Signal/Brake/Tail Lights: T3-3157R Lasfit has recently launched the new 3157 turn signals with improved features. With a power output of 24W and a brightness of 2000LM, these bulbs provide a brilliant red light to effectively alert vehicles and pedestrians behind you. The upgraded canbus system and cooling system enhance its overall performance compared to the previous version. We highly encourage all owners of Ram 2500 and 3500 to give these bulbs a try and upgrade their rear turn signal/brake/tail lights. https://cimg2.ibsrv.net/gimg/dodgefo...1f98246c2c.png Back up Lights: L-7443/L-T15 L-7443 for Ram 2500/3500 with projector L-T15 for Ram 2500/3500 with reflector The L-7443 is designed to provide a total output of 1200LM per set, making it suitable for the Ram 2500/3500 with projector. L-T10 series quips with few 3030 SMD LED chips, which offer an impressive 1400LM brightness. Both of them are capable of emitting a bright white light at 6000K, enhancing visibility for the rear of the vehicle during reverse maneuvers. Additionally, these bulbs are canbus friendly, ensuring compatibility with the Ram 2500/3500’s electrical system. Cargo Light: L-T15 3rd Brake Lights: L-T15R(Red) The Lasfit L-T15 bulb is designed to provide a bright output of 1400LM per set, ensuring sufficient brightness to alert vehicles behind you. Moreover, you can rest assured about compatibility issues as it is canbus supported, reducing the hassle of flickering lights. https://cimg3.ibsrv.net/gimg/dodgefo...6828e8b844.png License Plate Lights: L-T10 The L-T10 series features 3 bright 3030 lamp beads that can provide 800LM of brightness for the 2016-2018 Ram 2500/3500. With its 6000K white light, it can effectively illuminate the rear license plate, ensuring clear visibility. The 360° lighting effect ensures that no area is left in darkness, providing ample lighting for vehicles approaching from the rear. https://cimg7.ibsrv.net/gimg/dodgefo...145f53ff7e.png Interior LED Lights Map light: L-42MM The L-42MM festoon bulb from Lasfit is equipped with 7 3030 SMD LED chips, providing an extremely bright 6000K white light. It features an efficient aluminum heat sink System, which enables the LED bulbs to dissipate heat effectively, thereby extending the lifespan of the headlights. https://cimg3.ibsrv.net/gimg/dodgefo...bbf99a5550.png If you have any questions about this post or mentioned products, please leave a message in this forum. |
