Official Rapid Response Transmittal RRT, Recall & TSB Thread
Old May 4, 2010 | 09:30 PM
Doc Fluty's Avatar
Doc Fluty
Default Official Rapid Response Transmittal RRT, Recall & TSB Thread
If anyone has info on rapid response or recalls for 4th gen Rams, please PM me the details and i will post them in here.
please include the number, what it does and any other pertinent information
08-018-- Engine Controls - TIPM Update For ECM PROM Update Issues
08-007-- Cluster flash for fuel saver light
08-071--flash cluster for odometer issue
08-077--sirius inop due to initial subscription set to less than 1 yr.
08-081--crew cabs w/ sunroof. sunroof drain tubes
08-093--non-memory power pedals wont adjust. restore vehicle config through TIPM
08-101--inspect tailgate cap for warping or loose, replace if needed.
08-100--replace muffler. only factory duals w/ "quiet" muffler.
09-004--pcm flash for spark knock 1800-2500 rpm and/or NVH improvements in MDS
09-010--washer sensor weepage, replace washer harness w/ overlay
09-011--inspect ram box lids for warping, replace if needed (come pre-painted)
09-018--flash RER radio for update
09-020--zip tie rear axle vent tube to frame for possible hanging down
09-023--flash park assist module.
09-024--lube passenger seat rail or whatever (for creaking)
09-029--inspect for hood squeak
09-035--tailgate cover (taping)
09-041--2009 DS FLASH ABS/ESP MODULE
09-063--2009 DS - RAMBOX LOCK REPLACEMENT
09-084--Hood switch replacement
09-095--Inspect Window Molding
09-096--lens.lamp, high mounted stop lamp, replaced lense
10-009--Replace Exhaust Manifold Bolts
10-029--Replace Axle Disconnect Seal
14-001-- Fuel System - Difficult Fuel Fill/Nozzle Shuts Off
18-019 -- Engine Controls - MIL ON/Multiple DTC's Set
22-001 --Wheel shake/Tire flat spot
22-002 -- Wheels/Tires - Chrome Clad Wheel Balancing Information
26-001 -- Maintenance - Fluid Flushing Information
RECALLS:
J-10 -- Wiper Motor Replacement
Old Jul 26, 2012 | 08:42 AM
dirtydog's Avatar
dirtydog
Moderate User
I can help add to the list for anyone who has further TSB's or Recall information.
Just shoot me a PM with the correct info and it'll get done.
