2010 Ram 1500 with ESP BAS light
Old Dec 13, 2010 | 04:57 PM
phil41's Avatar
phil41
Default 2010 Ram 1500 with ESP BAS light
Can I do anything to fix this problem and the light of the truck with the lines from it is also on. What can I do or do I have to take it to a shop?
Old Dec 18, 2010 | 04:03 PM
lil_jo_25's Avatar
lil_jo_25
The funny thing is, I just had this problem Wednesday of this week. Answer this question for me. If your 4x4 light flashing and won't come off?
Old Jan 2, 2011 | 03:21 PM
Altair's Avatar
Altair
Dak attack!
Moving this to 4th gen Ram, you'll get more answers here.
Old Jan 5, 2011 | 04:52 AM
yotaman96's Avatar
yotaman96
My ESP BAS/SERV 4WD, traction control, and ABS lights kept coming on whenever it was wet out. Had to take the truck in for service. They said a sensor wire was pinched in the frame rail and had started to corrode. They replaced it and all is better so far.
Old Jan 5, 2011 | 05:55 AM
TDTIPMO's Avatar
TDTIPMO
This was just posted a day or two ago. Sounds like the same issue.
https://dodgeforum.com/forum/4th-gen...abs-error.html
Old Jan 5, 2011 | 12:39 PM
Charloz24's Avatar
Charloz24
Yes indeed I had this problem january 1st. You can also add my brother in law that had this problem last week on his 2010 TRX4.
Old Jan 6, 2011 | 09:44 PM
lil_jo_25's Avatar
lil_jo_25
Strange. I had a different issue. Mine was the 4x4 switch needed to be reset.
Old Jan 6, 2011 | 11:43 PM
Charloz24's Avatar
Charloz24
Mine was a bad sensor, my brother-in-law was A cutted wire....
Old Jan 8, 2011 | 07:36 PM
08KK's Avatar
08KK
Hey Phil, I work for Mercedes-Benz and since Chrysler & Mercedes merged they shared technology and now that they are split apart they still use similar products, ESP = electronic stability and BAS = Brake Assist and there is a 5inch braker switch that's plugged in right behind the brake pedal that always goes bad, check that
Old Mar 31, 2016 | 06:09 PM
Robyj33's Avatar
Robyj33
Default Same problem!
I just bought a 2010 Ram SLT 4x4 with the 5.7L Hemi, I am experiencing the exact same problem right now. I guess I should be calling the dealership. Lol
