ram subwoofer under front seats?
Hi, I have a 07 ram 1500 quad cab, I want to either buy or buildtwoenclosures for 10"subs that fits under the front seats.Under the rear seat is not an optionsince Ikeep the seat folded up and keep lots of tool boxs in that space.does anyone know of a company that makes them? or has anyone made em themselves with any luck? If I get creative with the shape I think if I build it myself I can get a box that has .60 cu. ft. I have two choices of subs. first 2 polk ex10 or second 2 pioneer ts-w251f. The polks need .65 cu. ft. and I can't find the specs for the pioneers I bought them a long time ago. Which ones should I use?
RE: ram subwoofer under front seats?
Don't stuff as much as you can. lol If you do that you'll cancel so many waves the sub will be inefficient, which doesn't help the Pioneers because the 251's are fairly inneficient already. It will also reduce the cooling ability of the subs by holding in heat, which isn't good for either of those models. Usually a doubled over layer in the bottom is plenty. But yes poly-fill is almost a must in that small space.
how bout a jl stealth box, a little high but it comes with a 13.5 sub that about 400w rms. i love jl stealth boxes i have one in my 00 ram it holds a 12 and it sounds like two 12s.
anyway check it out.
http://mobile.jlaudio.com/products_s...hp?fit_id=1535
