LOC Install question
I have a 2006 Ram mega cab, I built a custom sub box ran all wires and everything works fine except one issue. I wired the LOC Right behind the head unit and it works, The issue is that when i put the head unit on volume 1 the Subs are pounding like they are turned all the way up. But it down to zero they shut off completely. I tried turning gain down but you have to turn it down almost all the way then the subs dont increase in volume. Any help would be awesome. It does have the infinity 7 speaker W/o Navigation.
when i installed my LOC I only tapped into the left front speaker. I tapped into the dark green-yellow stripe (left front +) and dark green light blue stripe (left front -) wires, so you should be tied into the proper wires. I tapped into the wires before the main plug on the left side of the footwell on the drivers side. The wires you tapped into for the right speaker are the correct ones as well so maybe you have the polarity of one of the sets of wires wrong?
