Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Radio hdd issue
Old 08-20-2018, 03:36 PM
Phillip Fisher's Avatar
Phillip Fisher
Phillip Fisher is offline
Default Radio hdd issue
So I have an 09 1500 Laramie crew cab and the radio randomly freezes and resets. After messing with it a bit it seems to freeze when I’m trying to access music on the hdd. I can access pictures all day long though it seems a little slow to load sometimes. I have at least one song 100% for sure on the hdd. It showed up a few times but if I try to play it again it freezes and resets. I thought maybe the hard drive went out but I can access the photos on it and I can see the size and how much memory is left to use. Any idea what I need to do?
Old 08-20-2018, 09:45 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Any way to test the hard drive?
Old 08-21-2018, 05:27 AM
Phillip Fisher
Not that I know of.
Old 08-21-2018, 09:53 AM
ZEN357's Avatar
ZEN357
ZEN357 is offline
Being in the I.T. Field for over 25 years, it's sounds to me as if the hard drive has a bad place in it and it is going bad. Even solid state drive will go bad eventually. I would say you are going to have to have it replaced.
Old 08-21-2018, 11:43 AM
Phillip Fisher
OK thanks! That’s kinda what I was leaning towards doing but didn’t want to buy a new one if it was a software issue.
Old 08-25-2018, 12:38 PM
ultrasuperman's Avatar
ultrasuperman
ultrasuperman is offline
If it's a SATA HDD/SSD like what's in your computer you can test it with a program called HD Tune but I so know in some models the memory unit (like in my RB5 unit) is a proprietary SanDisk Flash unit
Old 08-25-2018, 01:04 PM
Phillip Fisher
Ok got the new hdd installed and that seems to have fixed all the problems I’ve had. Thanks again for the advice!!
Quick Reply: Radio hdd issue
