96 extended cab 4 door rear speaker install
I was installing the rear speakers in the 96 and running new speaker wire. When I got to where the wire in run into the rear doors I found a conector. I an wondering if anyone has removed said conector and if not what you might of done. And what was done to get the grummit (sp) back in place on the truck side if you keep the conector..
RE: 96 extended cab 4 door rear speaker install
Ok no one knows anything about these connectors?
Does this help? http://www.the12volt.com/installbay/...78731&PN=1
That does help but that is pretty much what I was planning on doing....it will be a pain but at lease it's only speaker wires in the connector I got to run threw
Thats the best way to do it.
