DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   Audio/Visual Electronics (https://dodgeforum.com/forum/audio-visual-electronics-16/)
-   -   custom radio won't work (https://dodgeforum.com/forum/audio-visual-electronics/99016-custom-radio-wont-work.html)
bradbates1998 Mar 22, 2007 06:55 PM
i have a 03 ram 2500 with a factory infinity system and i wanna put a pioneer cd with sat radio in it and when i hook it up nothing comes out of the speakers but the radio comes on someone told me to hook up the amp wire and i did and nothing happened then,,,, can someone help me !!!!!!!!
rtkota5point9 Mar 22, 2007 08:05 PM
RE: custom radio won't work
That should be it. Hook up the blue amp wire on the harness to the blue/white or blue (If theres no blue-white) on the headunit.
jeffgilliam.2005 Mar 23, 2007 12:10 AM
do you have sound at all when you switch it from radio to CD..???
brianas Mar 23, 2007 01:28 PM
double check the wires on you wriring harness
some aftermarket harness adapters have a dummy blue/wht wire
for a power ant and also another wire for the amp turn on
g/l
bradbates1998 Mar 25, 2007 08:09 PM
i looked at my harness and there is a amp wire and it is hooked up to the reciever i also called electronic express and they said i ned a interface or something like that i don't know what to do i want sat radio but i don't want that ugly screen on my windshield
bradbates1998 Mar 25, 2007 08:14 PM
i have a raz radio from the factory and if i can't get a custom radio to work i thought i would put a navigation radio in it but i need to know which one i need or if someone has a used one for sale and if it is difficult to install
rtkota5point9 Mar 25, 2007 09:08 PM
03's don't need any special interface. Just the wiring harness. You must have an issue with the factory amp turn on wire. Make sure the setting is correct in the radio to give that wire power. What model is it? Most Pioneers you can get to it by pressing "audio" until you get to the sub setting. You should be able to select it on and off and "norm" and "rev" Make sure it's turned "on" If you have a model with the organic OEL, the picture of the sub will change from and empty basket when it's off,to a complete sub with a cone when it's on. If that setting is off, the amp wire will get no power. To double check, if you have a multi-meter, check to see if you have 12V+ on that blue/white wire when the radio is on.
habeba86 Mar 26, 2007 02:50 AM
ORIGINAL: rtkota5point9
The amp should still power up with the sub turned off, it jst turns the sub rca out off.
rtkota5point9 Mar 26, 2007 12:01 PM
oh really? Ha ha, I figured it turned off the remote wire as well. [sm=oopssign.gif] Guess I never payed attention. Good call. But the rest of the post holds true. Test the amp turn on on the back of the headunit and see if it has 12V+.
habeba86 Mar 26, 2007 12:16 PM
Ya....if it was set-up like that, you would have to have the sub out on even if you were using an amp to power speakers.
© 2026 MH Sub I, LLC dba Internet Brands
