When are 07 Rams coming out
RE: When are 07 Rams coming out
ORIGINAL: jgralka
Um... I work there and yes we start on the 5th and then we are down for 3-6 weeks. I should know for sure how many at the end of this week. We are still working next week.
My guess is that because they have a 125 day supply of 06 rams and daks. So we are starting the 07 build on the 5th to fill about 4000 orders for 07's. And yes we go down the weeks of the 10th through the 24th. That is for certain. But the rumor mill says that we will bee down for two to three more weeks as well.
Joe
Joe
ORIGINAL: jgralka
Joe
Joe
ORIGINAL: shadowzform
This i do not understand....
WHY is dodge coming out with a 6.7l CTD that produces LESS horsepower and EQUAL lbs.-ft. of torque, when we have a 5.9l CTD?
For example: VW will actually be skipping the 2007 model year for their TDI models in the US because they don't have a diesel that can meet the new requirements. Their plan is to build up a huge inventory of 2006 models before the cutoff date, and see them throughout 2007. Then they will bring out a 2008 model late next year that meets the requirements.
Cummins has had to go from 5.9L to 6.7L because under the new pollution regs for NOx gases they have to use a lot of recirculated & cooled exhaust gas that cuts peak power output.
That same extra EGR is going to make Cummins owners have to change their engine lube oil much more often, because the EGR puts a lot of soot into the blowby gases.
MPG is going to be either slightly worse (Cummins press release)
or 15% worse (DCx subsidary Thomas Industries Cummins School Bus testing in North Carolina)
