95 dodge ram 1500 4x4 103K miles
due to bills and cash being more needed than the truck which is becoming a project more and more everyday i have no choice but to sell it, for much less than i have in it
this truck needs a fuel filler neck (85 dollars) a set of rear tires, and an oil change and it will be good to go..WILL NEED TO BE TOWED
95 dodge ram 1500HD 4x4 103K original miles
at 101K miles i replaced the following with brand NEW parts
all four front ball joints
front rotors,pads and installed bigger calipers
bigger battery
starter and starter wires
new fuel pump and filter
i need to sell this truck ASAP..ive got 3500 bucks into it, and its a great solid truck, again all it needs is a fuel filler neck, a set of rear tires (265/75/16's) and a oil change and its ready to work
2800 bucks FIRM is a good price for this low mileage truck, i dont wanna sell it but bills and such has left me no choice
the only rust on the truck is above the right rear tire..the doors have a lil bit of surface, its not a new truck by any means but for the price you cant find a better fixer upper, the motor and trans on this truck is completely solid, trans fluid is cherry red and the fluid n filter is only about 10k miles old
truck also has a flow master super 40 muffler on it and fresh black undercoating on the rockers
if you dont want the fog lights let me know and i can remove them
if you have any questions call or txt me @
815-508-7420
bigger battery
815-508-7420
