Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
ballast resistor
Old 07-11-2017, 06:12 PM
kirstina51's Avatar
kirstina51
kirstina51 is offline
Default ballast resistor
i have a 1971 dodge charger 383 auto tilt stering wheel. the ballast resister 2 prong smokes on putting on a new one. then fails eventually. this part of the starting cicurit.when it fails engine cranks but only starts when put in run condition. sounds like to much voltage i fiddled around with the starter switch many years ago tried a different one don't exactly remember back then. the tilt wheel has a certain starter switch that is mounted on the right side of the steering column close to the fire wall hard to get at.also a rare item to find. any help is wellcome.
Old 07-12-2017, 06:45 AM
Moparite's Avatar
Moparite
Moparite is offline
All the ballast does is cut down the voltage going to the coil during run. It should not smoke unless you have something wired wrong.
