Demon carburetor
Thanks for the information. I have an Edelbrock Thunder series AVS square bore that I need to install as the holley that is on it now has the bowls stripped and is dumping fuel causing the engine to stall. I think the scopps were on the sizzler package and I like the plain hood better (whick mine has),
FF
FF
I have MANY Holley carbs sitting around the garage, if you want, go get yourself a Holley brand carb kit, ship it to me, and I will rebuild it and replace whatever parts need replacing, and ship it back to you. PM me if you want to do that. The list number for the carb will be on the air horn, it should be an 1850, 600 cfm carb, but whatever it is, that is the number you will need to get the kit.
