Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
frame to gear reinforcmen (bracket)
Old 07-13-2017, 06:48 PM
lord jim's Avatar
lord jim
lord jim is offline
Default frame to gear reinforcmen (bracket)
W250 1993 Cummings
the bracket between power steering pump and frame ( pump bolts to bracket and through bracket to frame) cracked.
I'm trying to find new one, alternatively have it welded.
Any advise, experience shared greatly appreciated. - thanks.
Old 07-13-2017, 06:57 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,171 Likes on 2,924 Posts
Can you post a pic of the part in question?
Old 07-14-2017, 04:12 PM
lord jim's Avatar
lord jim
lord jim is offline
thanks for replay, two pics are attached one close up of crack near the bolt other showing part of steering pump, frame and bracket between.
Attached Thumbnails frame to gear reinforcmen (bracket)-20170714_115605.jpg   frame to gear reinforcmen (bracket)-20170714_115556.jpg
Old 07-14-2017, 05:57 PM
HeyYou is offline
Take the steering gear off, clean things REALLY well, and weld it up, in place. (so the bolt holes are still in the right spot.)
Old 07-16-2017, 11:03 PM
lord jim's Avatar
lord jim
lord jim is offline
thanks, I understand to weld bracket to the frame right? BTW any advise about reinforcing this part of frame as well?
thanks again
Old 07-17-2017, 09:22 AM
HeyYou is offline
No, don't weld it to the frame, weld up the cracks, or replace the bracket.
Maybe a steering box brace, to prevent it from happening again?
