DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
Innova 5610 Review: A Standout Among OBD II Scan Tools
Old Feb 6, 2026 | 06:11 PM
Curated Content Editor's Avatar
Dodge Forum Editor
Default Innova 5610 Review: A Standout Among OBD II Scan Tools
A feature-rich diagnostic scanner that caters to both DIYers and professionals, without the hefty price tag.
Disclosure: Innova is a paid sponsor of Dodge Forum.
  • The Innova 5610 features highly extensive, professional-grade bi-directional OBD II capabilities
  • It’s the top-of-the-line of hand-held automotive diagnostic scan tools
  • Innova even offers an optional OBD I kit for pre-1996 vehicles
  • It comes with advanced features such as OEM enhanced live data, TPMS read, battery and charging system test, active bi-directional tests, ABS bleeding, and more.
An online search for the “best OBD II scanner” will quickly lead to several mentions of the Innova CarScan Pro 5610 as one of, if not the, best DLC (datalink connector) diagnostic tools on the market at the moment. Among its many high-level features are real-time OEM-enhanced data, TPMS readings, ABS bleeding, active system tests, and full battery and charging system diagnostics. A quick search for top-rated OBD II scanners will almost certainly bring up the 5610—and for good reason. It’s the flagship tool from Innova, a U.S.-based company that has earned the trust of both home mechanics and seasoned technicians.
While professionals will find the tool incredibly useful, it’s also a perfect fit for hobbyists and serious DIYers. Personally, I used to rely on a basic Bluetooth OBD II dongle, which worked fine—until I got my hands on the 5610. Now, I’d be hard-pressed to go back.
More Than Just Code Reading
While its core function is to pull DTCs (diagnostic trouble codes), the 5610’s capabilities go far beyond that. Let’s take a closer look at what it offers and how it compares to other tools in its class.
Bi-Directional Control
One of the standout features of the Innova 5610 is its bi-directional control. This crucial capability is an immense help when diagnosing issues. Aside from receiving information from the vehicle’s computers, it allows you to actively command systems like fuel pumps, relays, and more to test functionality directly, something usually found only in much pricier tools. This can dramatically simplify troubleshooting for complex vehicle issues.
OEM Enhanced Diagnostics
The 5610 supports manufacturer-level diagnostics for many popular makes, including Honda, Ford, Toyota, GM, and Chrysler. It can access systems like ABS, SRS, and transmission control units, features that many entry-level scanners don’t provide.
To their credit, Innova is transparent about its limitations, especially when it comes to exotic or European vehicles. That said, in addition to testing it extensively on several Hondas and Acuras, I also used it with a 2008 Mercedes, and it worked perfectly in that case.
Real-Time Data and Graphing
The 5610 allows users to monitor live data from various vehicle systems, and it can display multiple data points simultaneously in graph form. This is particularly useful for diagnosing intermittent problems or verifying the effectiveness of a repair.
Reset and Relearn Support
The scanner goes beyond basics by including advanced reset and calibration options, such as:
  • Service light reset
  • Electronic parking brake (EPB) and ABS bleed
  • Battery system reset
  • Idle relearn
  • Steering angle sensor calibration
  • Crankshaft position sensor relearn
These procedures typically require a more expensive tool or a trip to the dealership.
Bluetooth Connectivity and RepairSolutions2 App
Innova pairs the 5610 with its RepairSolutions2 mobile app. Connecting the scanner to your smartphone adds additional functionality, including:
  • Access to a large repair database
  • Recall and TSB lookups
  • Maintenance schedules
  • Predictive failure analysis
It’s a handy companion, although not without its occasional hiccups (more on that below).
Performance in Use
Once plugged into the vehicle’s OBD II port, the 5610 powers on quickly and begins scanning immediately. On supported vehicles, the module scan is thorough and impressively fast. However, the depth of data you’ll see can vary depending on what your vehicle’s ECU allows access to.
The interface isn’t touchscreen-based, but the physical buttons are responsive, and the menu layout is straightforward enough for first-timers. The full-color screen is bright and readable, even under direct sunlight. Build quality is also excellent; the tool feels durable and fits comfortably in the hand.
Limitations
No tool is perfect. Some of the 5610’s drawbacks include:
  • Not all advanced features are compatible with every make or model
  • The RepairSolutions2 app can be finicky—sometimes requiring re-pairing or re-logging in
  • Updates can’t be done over-the-air; you’ll need a computer and a separate update tool
  • Navigating live data can be tedious, especially with long parameter lists
Innova even put out a tongue-in-cheek blog post titled 5 Reasons You Shouldn’t Buy an Innova 5610,” where they outline these limitations transparently, something you rarely see from tool manufacturers.
Who Should Buy It?
If you’re someone who enjoys working on your own vehicles but wants more than just a basic code reader, the 5610 is an ideal choice. It’s also a solid option for independent shops needing a capable, portable backup scanner.
  • Serious DIYers and home mechanics
  • Small repair shops or mobile techs
  • Anyone looking for dealer-level features at a fraction of the price
It’s not a replacement for OE-level diagnostics in a dealership environment, but it covers 90% of what most people need, and it does so exceptionally well. For those wanting to move up from entry-level tools without dropping thousands, the Innova 5610 might just be the best deal in the game.
